Hernandezh185
Jul 04, 2019Aspirant
NightHawk Xr 500 pro gaming
I have a problem trying to connect to my Nighthawk XR500. I have AT&T as an internet provider. Please help!!!
Netduma_Alex
Jul 05, 2019NetDuma Partner
So you've got an AT&T provided modem I assume? You have connected that with an ethernet cable to the WAN port on the XR500, and then gone through the setup procedure, but can't get an internet connection?
Do you need a PPPoE login for your network? Did your previous router have any settings that you needed to change to get it to work?
Hernandezh185
Jul 05, 2019Aspirant
Yes I have a problem trying to connect my devices to the router such as my ps4 it keeps giving me an error code
- Netduma-FraserJul 05, 2019NetDuma PartnerWhat error code are you getting? Are any devices successfully connected to the router? Is it just the internet you can't access or the interface as well?
