JohnWalkden
Aug 31, 2020Aspirant
Nighthawk XR 500 slow wifi speeds
I have an XR 500. The modem is the virgin V3. The app speeds im geting are 376 download & 36.96 upload. When i run a wifi speed checker i get download 22 & upload 32. Ive changed he ...
JohnWalkden
Sep 03, 2020Aspirant
I changed from smart and it seemed ok, it seems it not to be sending out a WiFi signal. Although the speed test through the app is good.
CO fused.
CO fused.
Netduma-Fraser
Sep 03, 2020NetDuma Partner
What do you mean by it's not sending out a signal?
