Perplexx259
May 01, 2019Aspirant
Nighthawk Xr 500
Hi Ich habe folgendes Problem... Ich habe meine Xbox mit Kabel an den Router geschlossen, der Router läuft über mein Modem. Die Konsole verbindet sich mit dem Internet, wenn ich aber die X...
Netduma-Fraser
May 01, 2019NetDuma Partner
It's hard to understand the translation exactly, could you clarify? You're trying to connect to the Xbox app on your phone but it doesn't work is that correct? Are both the Xbox and the phone connected to the XR500?
Perplexx259
Hey. Yes. Both devices are coneccted.
I Start the Xbox smartglass App & it finds my Xbox,it connectet it for 2 seconds & then it loss the Connection & this Happens over and over again
