Perplexx259
May 01, 2019Aspirant
Nighthawk Xr 500
Hi Ich habe folgendes Problem... Ich habe meine Xbox mit Kabel an den Router geschlossen, der Router läuft über mein Modem. Die Konsole verbindet sich mit dem Internet, wenn ich aber die X...
Perplexx259
Hey. Yes. Both devices are coneccted.
I Start the Xbox smartglass App & it finds my Xbox,it connectet it for 2 seconds & then it loss the Connection & this Happens over and over again
Netduma-Fraser
May 01, 2019NetDuma Partner
Which WiFi are you connected to? Try 2.4GHz. Also put your Xbox IP into DMZ in WAN Setup.
- Perplexx259May 01, 2019AspirantI pur the Xbox Into the dmz & im in the 2.4 g
Still Not work :/- Netduma-FraserMay 01, 2019NetDuma PartnerTurn of the cellular data network on your phone and just have it connected to the wifi, it may be getting confused, does it work then?
- Perplexx259May 01, 2019AspirantSorry... still Not working... the same Happens when i Try it with the Laptop... so its Not the mobil data
