Perplexx259
May 01, 2019Aspirant
Nighthawk Xr 500
Hi Ich habe folgendes Problem... Ich habe meine Xbox mit Kabel an den Router geschlossen, der Router läuft über mein Modem. Die Konsole verbindet sich mit dem Internet, wenn ich aber die X...
Perplexx259
Yes... all devices are conecctet to the 2.4g Network... only the Xbox is on a cable connectet to the Router
And also After Turn off the ALG it still Not work 😕
If it Not gonna work, it May a Garbage Router.
Always the same with netgear... i‘m sick of it .😤
Netduma_Jack
May 02, 2019NetDuma Partner
If you connect the devices directly to your modem, does the issue continue?
- Perplexx259May 02, 2019AspirantHow do u meen that ?
I cant connect my Smartphone or laptop to the Modem cause there is no wlan... - Netduma-FraserMay 02, 2019NetDuma PartnerConnect both the console and phone to the same wireless and then try please
- Perplexx259May 03, 2019AspirantWow... that Works perfekt...
But how can i handle this with a wired Xbox ... - Netduma-FraserMay 04, 2019NetDuma PartnerOkay so it can work that's great. Now connect the Xbox wired to the XR500 and keep the phone on the same XR500 wifi. Set a static/reserved IP address for both devices in the XR500 LAN Settings. Then reboot the router, does it work then? Also untick Disable IGMP Proxying just in case in WAN Settings.
- Perplexx259May 06, 2019AspirantI set the Reserved ip for the Xbox.
Also for my phone...
Sometimes it work After that, But still it wont work....
May it cause the rip Funktion in the lan Settings ? - FURRYe38May 06, 2019Guru - Experienced User
Use default RIP settings on the XR router. Nothing different as it's not needed in a home setting.
Did you power OFF the xbox before connecting the LAN cable from the XR router to the back of the xbox?You sure your using a good working qualtiy LAN cable? CAT6 is recommended.
- Netduma-FraserMay 06, 2019NetDuma PartnerI know with some things like that for example a smart TV both devices have to be connected to the exact same network e.g. 5GHz wifi not 5 & 2.4GHz so I would assume this is that same scenario but I don't know why they restrict it like that.
