xAce
Oct 13, 2021Aspirant
Nighthawk XR1000 | Worst Purchase So Far... Please help
Hi, I want to start off by saying that I've tried to figure things out but this is so frustrating, am I doing something wrong or is this the worst router? I purchased a Nighthawk XR1000 to he...
xAce
Smart connect was disabled, I tried it once but had issues of constant switching.
I can try that configuration but I wasn't very far from the Router when ,y phone was having connection issues.
Thoughts on disabling the XR1000 WiFi and just using the Orbi in AP Mode? If this antenna config and 5Ghz doesn't help.
Netduma-Liam
Oct 14, 2021NetDuma Partner
That's certainly something you can try! Let us know how you get on with it all and we then know where to look.
- xAceOct 15, 2021Aspirant
I made the recommended changes, left both WiFi's on and it seems to be running fine.
I do have some other questions:
Why are 90% of the connected Devices listed as "Unnamed"? Do I have to manually rename them all?
And
I don't have this many devices connected, so what could be causing so many to appear? As for LAN, I only have a gaming PC and the Orbi plugged in.
- Netduma-FraserOct 15, 2021NetDuma PartnerGlad to hear that! Are the devices in question connected to the Orbi? If so that makes sense, they may not be able to determine what the devices are properly in this configuration. If you connect one device to 2.4/5GHz/ethernet they may show up as a different device as the MAC address it different
