MrElios300
May 02, 2022Guide
Nighthawk XR1000 and TIMHUB
Hi, I recently bought a second hand Nighthawk XR1000 from Amazon Warehouse ("like new" condition) but I can't manage to set up it. I followed Nighthawk App instructions, tried Static IP, Pppoe, but no...
- May 03, 2022
Netduma-Fraser Netduma-Liam plemans
Solved... I tried a speedtest on my PC on WiFi and it worked really fine (almost the same as ethernet connection), so I tried on the browser on my Galaxy M31S and I got same results. So I looked at the app settings and discovered that it was showing MB/s not Mbps, I think it automatically changed after an update. I'm really sorry for wasting your time, I feel like a real dumbass.
I really appreciate your support, thank you so much. I apologize again.
May 03, 2022Guru - Experienced User
Go into the timhub and set the netgears IP address into its DMZ. Most timhub's are modem/router combo devices.
