MrElios300
May 02, 2022Guide
Nighthawk XR1000 and TIMHUB
Hi, I recently bought a second hand Nighthawk XR1000 from Amazon Warehouse ("like new" condition) but I can't manage to set up it. I followed Nighthawk App instructions, tried Static IP, Pppoe, but no...
- May 03, 2022
Netduma-Fraser Netduma-Liam plemans
Solved... I tried a speedtest on my PC on WiFi and it worked really fine (almost the same as ethernet connection), so I tried on the browser on my Galaxy M31S and I got same results. So I looked at the app settings and discovered that it was showing MB/s not Mbps, I think it automatically changed after an update. I'm really sorry for wasting your time, I feel like a real dumbass.
I really appreciate your support, thank you so much. I apologize again.
MrElios300
May 03, 2022Guide
First of all thank you both for your support. Netduma-Liam plemans
My PC was already connected to XR via an ethernet cable (CAT6), but going to routerlogin.net resulted in "No internet connection" chrome page. I solved connecting it via WiFi (honestly I don't know why it worked this way), I followed setup wizard and it changed the Gateway to 10.0.0.1 , so now 10.0.0.1 is the DumaOS login page and 192.168.1.1 is the TIMHUB login page. Would you recommend another connection type like Static IP or PPPoE? (I'll connect only XR to TIMHUB modem/router and use it for gaming, multimedia broadcasting, office, ecc...)
But I have another problem right now, my WiFi speed is really slow. As I said previously I have FTTC (100/20Mbps profile), if I do a speedtest with the PC connected via ethernet (that after setup works fine) I get 80 to 90 Mbps in download and 20Mbps in upload, but if I do the same on my Galaxy M31S connected via WiFi 5Ghz (below 50cm from XR) via OOKLA Speedtest app I get only 10Mbps in download and 2.5Mbps in upload. I've already disabled TIMHUB WiFi and tried completely disabling QoS, but nothing changed.
Netduma-Fraser
May 03, 2022NetDuma Partner
You don't choose whether or not to use PPPoE, you either require it or you don't, as you have internet you do not need it so you can leave that alone now. Have you disabled Smart Connect then for the WiFi?
