MrElios300
May 02, 2022Guide
Nighthawk XR1000 and TIMHUB
Hi, I recently bought a second hand Nighthawk XR1000 from Amazon Warehouse ("like new" condition) but I can't manage to set up it. I followed Nighthawk App instructions, tried Static IP, Pppoe, but no...
- May 03, 2022
Netduma-Fraser Netduma-Liam plemans
Solved... I tried a speedtest on my PC on WiFi and it worked really fine (almost the same as ethernet connection), so I tried on the browser on my Galaxy M31S and I got same results. So I looked at the app settings and discovered that it was showing MB/s not Mbps, I think it automatically changed after an update. I'm really sorry for wasting your time, I feel like a real dumbass.
I really appreciate your support, thank you so much. I apologize again.
Netduma-Fraser
May 03, 2022NetDuma Partner
Do you still have that WiFi enabled as that can interfere with the XR WiFi, if you do disable that and then retest please. Also for the XR antennae set them like this _ | | _
MrElios300
May 03, 2022Guide
- Netduma-LiamMay 04, 2022NetDuma Partner
Ah I see, well thanks for letting us know!
No need to apologise, thanks for troubleshooting it with us.
- plemansMay 04, 2022Guru - Experienced User
Glad to hear it was just a misunderstanding of settings 🙂
Hope it works great for you!
