Deijeneiro
Sep 16, 2021Guide
Nighthawk XR1000 Autodetect Bandwidth
Dear Netgear and community, My internet is fiber optic.
Now I have my Netgear Router directly connected to the fiber optic via PPPoE connection.
Everything works except when I test the automati...
Sep 16, 2021Guru - Experienced User
Don't use the built in speedtest. Its not accurate because it rarely chooses the best server.
You can manually setup your speeds in the qos if you're wanting qos
Deijeneiro
Sep 16, 2021Guide
True, but nevertheless if I put the right speed.
Then if I run the benchmark test. It says 345 of the 1000 mbit for the upload and therefor my score is A/B instead of A+.
