Deijeneiro
Sep 16, 2021Guide
Nighthawk XR1000 Autodetect Bandwidth
Dear Netgear and community, My internet is fiber optic.
Now I have my Netgear Router directly connected to the fiber optic via PPPoE connection.
Everything works except when I test the automati...
Netduma-Fraser
Sep 16, 2021NetDuma Partner
We're still improving the reporting of Benchmark and Auto Detect Speeds, not to worry though you can just enter it in manually and continue to get the speeds you expect.
Deijeneiro
Sep 16, 2021Guide
So just ignore the speeds and benchmarks then, for now?
- Netduma-FraserSep 16, 2021NetDuma PartnerYes that's what I would recommend. With your speeds you're unlikely to saturate the connection enough where bufferbloat would be much of an issue
- DeijeneiroSep 16, 2021Guide
Oke, will do that. Thanks for the reply!
