Deijeneiro
Sep 16, 2021Guide
Nighthawk XR1000 Autodetect Bandwidth
Dear Netgear and community, My internet is fiber optic.
Now I have my Netgear Router directly connected to the fiber optic via PPPoE connection.
Everything works except when I test the automati...
Deijeneiro
Sep 16, 2021Guide
So just ignore the speeds and benchmarks then, for now?
Netduma-Fraser
Sep 16, 2021NetDuma Partner
Yes that's what I would recommend. With your speeds you're unlikely to saturate the connection enough where bufferbloat would be much of an issue
- DeijeneiroSep 16, 2021Guide
Oke, will do that. Thanks for the reply!
