Deijeneiro
Sep 16, 2021Guide
Nighthawk XR1000 Autodetect Bandwidth
Dear Netgear and community, My internet is fiber optic.
Now I have my Netgear Router directly connected to the fiber optic via PPPoE connection.
Everything works except when I test the automati...
Netduma-Fraser
Sep 16, 2021NetDuma Partner
Yes that's what I would recommend. With your speeds you're unlikely to saturate the connection enough where bufferbloat would be much of an issue
Deijeneiro
Sep 16, 2021Guide
Oke, will do that. Thanks for the reply!
