ashleyeliz
Aug 28, 2023Aspirant
Nighthawk XR1000 Blocking all Steam Connections
Starting last week, my router started blocking all steam server access for downloads and online play. A gaming router.. blocking gaming. I have had this router with no issues for three years. Af...
Netduma-Fraser
Aug 28, 2023NetDuma Partner
Have any settings or anything else in your network changed prior to this happening? How did you disable QoS exactly? If you disable the Geo-Filter does that allow you to connect?
- ashleyelizAug 28, 2023Aspirant
Nothing has changed, at all. QoS disabled within DUMAOS, under QoS then congestion control, disable QoS.
Not sure how to fully disable geo-filtering. I normally have to reset the timezone because it puts me on the wrong coast all the time. But, even on the eastern coast, it makes no difference.
Also, I attempted to port forward every port that steam uses, got it to work for a couple minutes, then the router shut off. Restarted, and rest all settings.
- Netduma-FraserAug 28, 2023NetDuma PartnerOn the Geo-Filter you manually put your location so you don't need to worry about the timezone. If you have a device added it'll either be disabled or in filtering mode or you can remove it completely. So if you disable or remove the device does it then work?
There are no devices in the list.
