ashleyeliz
Aug 28, 2023Aspirant
Nighthawk XR1000 Blocking all Steam Connections
Starting last week, my router started blocking all steam server access for downloads and online play. A gaming router.. blocking gaming. I have had this router with no issues for three years. Af...
Netduma-Fraser
Aug 28, 2023NetDuma Partner
Have any settings or anything else in your network changed prior to this happening? How did you disable QoS exactly? If you disable the Geo-Filter does that allow you to connect?
ashleyeliz
Nothing has changed, at all. QoS disabled within DUMAOS, under QoS then congestion control, disable QoS.
