ashleyeliz
Aug 28, 2023Aspirant
Nighthawk XR1000 Blocking all Steam Connections
Starting last week, my router started blocking all steam server access for downloads and online play. A gaming router.. blocking gaming. I have had this router with no issues for three years. Af...
ashleyeliz
Aug 29, 2023Aspirant
It is not ISP owned, it is my own Netgear modem and its CM1200
Aug 29, 2023Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
- ashleyelizAug 29, 2023Aspirant
Time
Priority
Description
Tue Aug 29 10:42:23 2023
Error (4)
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=0;CMTS-MAC=0;CM-QOS=1.1;CM-VER=3.1;
Tue Aug 29 01:57:44 2023
Notice (6)
CM-STATUS message sent. Event Type Code: 5; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=0;CMTS-MAC=00;CM-QOS=1.1;CM-VER=3.1;
Tue Aug 29 01:57:33 2023
Warning (5)
Dynamic Range Window violation
Warning (5)
RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=0;CMTS-MAC=0;CM-QOS=1.1;CM-VER=3.1;
Warning (5)
Warning (5)
Warning (5)
REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=0;CMTS-MAC=0;CM-QOS=1.1;CM-VER=3.1;
Tue Aug 29 01:57:29 2023
Notice (6)
DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=0;CMTS-MAC=0;CM-QOS=1.1;CM-VER=3.1;
Tue Aug 29 01:57:24 2023
Notice (6)
TLV-11 - unrecognized OID;CM-MAC=0;CMTS-MAC=0;CM-QOS=1.1;CM-VER=3.1;
Warning (5)
DHCP WARNING - Non-critical field invalid in response ;CM-MAC=00000;CMTS-MAC=0;CM-QOS=1.1;CM-VER=3.1;
Time Not Established
Notice (6)
Honoring MDD; IP provisioning mode = IPv4
Critical (3)
SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=00000;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Tue Aug 29 01:56:25 2023
Critical (3)
Resetting the cable modem due to docsDevResetNow
Tue Aug 29 01:51:34 2023
Notice (6)
CM-STATUS message sent. Event Type Code: 5; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=00000;CMTS-MAC=00000;CM-QOS=1.1;CM-VER=3.1;
Tue Aug 29 01:51:22 2023
Warning (5)
Warning (5)
RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=00000;CMTS-MAC=00000;CM-QOS=1.1;CM-VER=3.1;
Warning (5)
REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=00000;CMTS-MAC=00000;CM-QOS=1.1;CM-VER=3.1;
Tue Aug 29 01:51:18 2023
Notice (6)
DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=00000;CMTS-MAC=00000;CM-QOS=1.1;CM-VER=3.1;
Notice (6)
TLV-11 - unrecognized OID;CM-MAC=00000;CMTS-MAC=00000;CM-QOS=1.1;CM-VER=3.1;
Tue Aug 29 01:51:17 2023
Warning (5)
DHCP WARNING - Non-critical field invalid in response ;CM-MAC=00000;CMTS-MAC=00000;CM-QOS=1.1;CM-VER=3.1;
Tue Aug 29 01:51:13 2023
Notice (6)
Tue Aug 29 01:51:04 2023
Critical (3)
No Ranging Response received - T3 time-out;CM-MAC=00000;CMTS-MAC=00000;CM-QOS=1.1;CM-VER=3.1;
Tue Aug 29 01:50:52 2023
Critical (3)
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=00000;CMTS-MAC=00000;CM-QOS=1.1;CM-VER=3.1;
Tue Aug 29 01:50:45 2023
Critical (3)
DHCP FAILED - Discover sent, no offer received;CM-MAC=00000;CMTS-MAC=00000;CM-QOS=1.1;CM-VER=3.1;
Tue Aug 29 01:49:42 2023
Notice (6)
Tue Aug 29 01:49:36 2023
Critical (3)
Tue Aug 29 01:49:15 2023
Critical (3)
Tue Aug 29 01:49:08 2023
Critical (3)
Tue Aug 29 01:48:05 2023
Notice (6)
Tue Aug 29 01:47:53 2023
Critical (3)
Tue Aug 29 01:47:39 2023
Critical (3)
Tue Aug 29 01:47:28 2023
Critical (3)
Tue Aug 29 01:46:29 2023
Notice (6)
Tue Aug 29 01:46:16 2023
Critical (3)
Tue Aug 29 01:46:05 2023
Critical (3)
Tue Aug 29 01:45:06 2023
Notice (6)
Tue Aug 29 01:44:51 2023
Critical (3)
Tue Aug 29 01:44:17 2023
Warning (5)
B-INIT-RNG Failure - Retries exceeded;CM-MAC=00000;CMTS-MAC=00000;CM-QOS=1.1;CM-VER=3.1;
Critical (3)
Tue Aug 29 01:42:43 2023
Critical (3)
TFTP Request Retries exceeded, CM unable to register
- FURRYe38Aug 29, 2023Guru - Experienced User
Seeing lots of issues here. Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Please post the Cable Connections page when you get a chance.
