Marv921
Sep 19, 2022Aspirant
Nighthawk xr1000 blocks fall guys
Hi, Nighthawk xr1000 blocks fall guys. Any ideas?
Sep 19, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
This game on PC or game console?
How is the router configured?
- Marv921Sep 19, 2022AspirantHey mates, im playing on ps5. I have everything perfect connected and the settings are also ok. Im working im IT…
- FURRYe38Sep 19, 2022Guru - Experienced User
So you got the problem fixed?
- Netduma-FraserSep 19, 2022NetDuma PartnerIt's highly likely the Geo-Filter causing it, if you disable Filtering Mode does it work?
- Marv921Sep 19, 2022AspirantSadly its not the geofilter, i thought i before. Makes no sense for me
