Marv921
Sep 19, 2022Aspirant
Nighthawk xr1000 blocks fall guys
Hi, Nighthawk xr1000 blocks fall guys. Any ideas?
Sep 19, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
This game on PC or game console?
How is the router configured?
Marv921
Hey mates, im playing on ps5. I have everything perfect connected and the settings are also ok. Im working im IT…
- FURRYe38Sep 19, 2022Guru - Experienced User
So you got the problem fixed?
- Netduma-FraserSep 19, 2022NetDuma PartnerIt's highly likely the Geo-Filter causing it, if you disable Filtering Mode does it work?
