JA23
Nov 28, 2021Aspirant
Nighthawk XR1000 Bufferbloat high
I just got a XR1000 and was working on it all day to try and make it run right but im getting anywhere from 100 to 200 less download speed and my download buffer bloat is higher than my isps router/m...
Netduma-Fraser
Nov 29, 2021NetDuma Partner
Where are you testing the speed and bufferbloat exactly, using Connection Benchmark? If so we are still improving on the reporting from the feature so you can take the results with a pinch of salt.
JA23
Nov 29, 2021Aspirant
I’m using waveform connection benchmark and I tried using dslreport but for some reason it hasn’t been working with my xr1000 connected
