JA23
Nov 28, 2021Aspirant
Nighthawk XR1000 Bufferbloat high
I just got a XR1000 and was working on it all day to try and make it run right but im getting anywhere from 100 to 200 less download speed and my download buffer bloat is higher than my isps router/m...
Nov 29, 2021Guru - Experienced User
what modem/gateway is the XR connected to?
What speeds do you pay for?
What speeds do you get hardwired into the modem/gateway?
JA23
Nov 29, 2021Aspirant
My XR is connected to the xFi Gateway 3rd Generation, I pay for 1000 download and usually get around 940 when plugged into my isp provided router/modem but on my XR get in the 700s for download upload is good though same thing with my bufferbloat only download is bad
- plemansNov 29, 2021Guru - Experienced User
Is the router's IP address entered into the xFi's DMZ? or is the xFi in modem only mode?
- JA23Nov 29, 2021AspirantIt’s acting as a modem only I put it in bridge mode
- Netduma-LiamNov 30, 2021NetDuma Partner
If you completely disable QoS from the three-line menu in Congestion Control, does this improve the speeds?
