Ehull5
Nov 11, 2020Aspirant
Nighthawk XR1000 Dos Attack Issues
[DoS attack: Fraggle Attack] from source 66.129.201.32,port 10001 Ok I'm not very tech savvy when it comes to router and DDOS attacks but I am currently a full time content creator on youtube/twitch ...
Netduma-Fraser
Nov 11, 2020NetDuma Partner
DoS attacks on NG routers are normal and generally false positives. What are the connection issues you're having exactly and what settings are you using?
Ehull5
Settings are basically the defaults as I’ve just gotten the router. Essentially my stream will disconnect from the Twitch server but my internet wouldn’t go out. It was very odd.
- Netduma-FraserNov 12, 2020NetDuma PartnerDisable DumaOS Classified Games on the QoS page under Traffic Prioritization and any other rules you may have added there and see if that resolves it please.
