Kenno
Feb 05, 2021Follower
Nighthawk XR1000 "DumaOS Not Loaded Yet"
G'day, I recently just got a Nighthawk XR1000 approximately five days ago. I have an issue where the device is stuck on a webpage with the following notification and will not load further. ...
Netduma-Fraser
Feb 09, 2021NetDuma Partner
Usually this can be resolved with a reboot, have you done this to see if that works?
- MichaelwilMar 07, 2021InitiateI also have the same problem and rebooting doesn’t make a difference
- Netduma-FraserMar 07, 2021NetDuma PartnerOn the System Information page in the Rapp panel options change the number of retries to 5, then reboot from the interface and see whether it works then please
- iTzPookieJun 25, 2022Tutor
what system information page and what RAPP panel are you talking about. i have no idea where that is, nor do i see any of that anywhere.
