Webbo
Dec 12, 2022Aspirant
nighthawk XR1000 geo filter not working!!!!
I picked a netgear XR1000 up 3 days ago and the geo filter has only worked once. I'm from the UK and wanted to play on American servers and it won't let me move servers again it's like the geo filter...
Dec 12, 2022Guru - Experienced User
Take a look at the bottom of this guide: http://support.netduma.com/en/support/solutions/articles/16000077072-dumaos-optimal-settings-guide-geo-filter
it will let you know how to allow your friends so that you can connect to them when you are using filtering mode. Could you provide a screenshot of the Geo-Filter when you see the server outside your radius please? Then I can best advise.
What browser are you using?
Please take a screen capture of what your seeing.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200
GeoFilter is working for me however I'm in the USA:
Webbo
Hey man, is there anything I can discuss this further with you on like discord? I'm currently not at home so I won't be available today.
