Steinmeg
Mar 21, 2022Star
Nighthawk XR1000 intermittent drops wifi
Well where to start, so set was iffy at best pages took a long time to load. Upgraded to 1gb up/down and had to restart router. Did that and router took about 10 minutes to comeback online. Changed se...
- Mar 22, 2022Are you using Armor? If so disable that as we've seen that cause some issues in the past. In LAN Settings, set static/reserved IPs for the devices, apply, reboot from the interface, wait 2 minutes before accessing/using the internet and then see if it appears to be more stable.
Netduma-Liam
Mar 22, 2022NetDuma Partner
Good questions above from FURRYe38, that would be useful to know.
In addition, I'd suggest factory resetting the XR1000 since upgrading the line, this is important to do as it'll be like a new connection to the XR.
Are wired devices also dropping connection or is it just wireless clients?
When devices drop connection, are you still able to access the DumaOS interface by going to 192.168.1.1 or routerlogin.net in your web browser?
Let us know.
