Dank90
Nov 05, 2022Aspirant
Nighthawk xr1000 intermittently drops internet connection
I have an Nighthawk XR1000 on version 1.0.0.64_1.0.49 connected to a Nighthawk CM1200 modem, the router will just randomly go from connected to disconnected status for internet and my PC connected vi...
Dank90
yup I went through some articles for my model https://www.netgear.com/support/product/xr1000.aspx#download and it looks like I am on latest firmware version but the firmware version may also be the issue so would need a recommended stable version to roll back to if that is the case.
michaelkenward
Nov 05, 2022Guru - Experienced User
Dank90 wrote:
... so would need a recommended stable version to roll back to if that is the case.
Not something you will find here.
Try in the appropriate section.
