Scratch159
Jun 30, 2022Tutor
Nighthawk XR1000 no internet
I have an Arris TM1602 modem that shows that it is connected to the internet. Although, my Nighthawk XR1000 shows that both wifi bands are able to be connected to, they don’t have access to internet. ...
- Jul 01, 2022You can either hold the reset button in the back of the router with a pin or something similar for 30 seconds, wait 2 minutes then access the interface and go through the wizard or
instead of the physical button, if you have access you can go to Settings > Administration > Backup Settings and click erase
Jun 30, 2022Guru - Experienced User
Using WPA2 and AES only for security?
Have you tried a factory reset and setup from scratch using a wired PC?
Scratch159
Jun 30, 2022Tutor
The firmware is up to date. WPA2 password for security. I have tried factory resetting from my phone but I don’t have a pc with an Ethernet port - all fairly new laptops.
