Xavy
May 01, 2024Aspirant
Nighthawk XR1000 not connecting to the Internet
So I'm trying to use this router that I have, I honestly didn't buy it I have no clue how it got there but before I go to buy another one I'm trying to get this XR1000 one to work. Me and my family ha...
May 01, 2024Guru - Experienced User
What Firmware version is currently loaded on the XR router?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
- XavyMay 22, 2024AspirantUnfortunately I do not know the answer to most of the questions 😅 but this is what I am trying to connect the Netgear router to. Idk if this is possible to do. I connected this to the router using the cable given to us, and then I tried a cat6a cable and still nothing 😕
- XavyMay 22, 2024AspirantAlso sorry yes I did try and restart everything and still no cigar :c
- Netduma-FraserMay 23, 2024NetDuma PartnerYou don't need internet access to access the router interface - what do you see when putting http://192.168.1.1 in your web browser?
- XavyJun 02, 2024AspirantNothing happens 😞
