Maloney714
Aug 03, 2022Initiate
Nighthawk XR1000 ok to use in AP Bridge mode?
Hi Guys, hope all who read are well? I just wanted to ask if it's better to run the Nighthawk XR1000 in bridge mode? I have noticed, as you would, a massive reduction in options for the access po...
Netduma-Liam
Aug 04, 2022NetDuma Partner
As rightly mentioned above, AP mode disables all DumaOS features and leaves the router acting as an access point.
We'd suggest running the XR1000 in router mode, if you have any issues with this configuration I'm sure we can assist you to resolve them.
Maloney714
Aug 04, 2022Initiate
Hi, thanks for your reply. I'm having issues with IP addressing on the network, it's addressing with 10.0.0.1 and so on. I wanted the router to keep the original 192.168.1.1 and so on...
Is there a way to have the router continue the addressing like that please? when I try to change the setting I get an addressing conflict warning and it fails
Thanks in advance
Kind regards
- Netduma-LiamAug 04, 2022NetDuma Partner
It'll be doing this because the upstream router also uses the LAN IP of 192.168.1.1. If you want the XR to have this address, change the LAN IP of the upstream router/modem to something else.
