Ricktheracefan
Apr 10, 2022Star
Nighthawk XR1000 Router - Reboots every few hours
I have had this router for about 2 months and the performance is great when it works - however it reboots every few hours. This is destroying my ability to work from home and to enjoy gaming. Whe...
- Apr 10, 2022There is a more up to date firmware so I would recommend installing that and then doing a factory reset for a fresh setup and see if it makes a difference. Otherwise, is the router connected to an power extender or direct to a wall outlet? We've seen issues like this resolved when it's connected direct to an outlet.
Ricktheracefan
Apr 10, 2022Star
It is plugged into a power strip - I will try moving it to a direct wall outlet.
What firmware is available that is more up to date? I did update it it and reset when I first received it but it now claims it is up to date. I'll do a look around for a newer version manually.
Edit - I found XR1000-V1.0.0.64_1.0.49 on this site - will be updating and will report result.
Thanks
Apr 11, 2022Guru - Experienced User
What CAT# LAN cable is connected between the router and ISP Modem/ONT?
- RicktheracefanApr 12, 2022StarMy XFinity Modem info is below:Model:CGM4331COMVendor:TechnicolorHardware Revision:2.0Serial Number:************************Processor Speed:1503 MHzDRAM Total Memory:1024 MBDRAM Used Memory:680 MBDRAM Available Memory:344 MBFlash Total Memory:2048 MBFlash Used Memory:134 MBFlash Available Memory:1914 MBeMTA & DOCSIS Software Version:Prod_20.2_d31 & Prod_20.2Software Image Name:CGM4331COM_4.11p7s1_PROD_seyAdvanced Services:CGM4331COMPacket Cable:2.0
- Netduma-LiamApr 13, 2022NetDuma Partner
How're you getting on with the new firmware? Has it helped?
- RicktheracefanApr 14, 2022Star
After I update the firmware I was hopeful but it rebooted after about 2 hours. I then moved it out of power strip and directly to wall and no issues since - uptime now over 4 days.
UptimeRouter TimeTime ZoneBoard ModelFirmware VersionDumaOS Version
4 days 1 hour 41 minutes 51 seconds Thu Apr 14 21:27:20 2022 (GMT-5:00) Eastern Time (US & Canada) XR1000 1.0.0.64_1.0.49 3.1.1
