bobbydigital00
Oct 17, 2022Apprentice
Nighthawk XR1000 SLOW....SLOW...SLOW...!!!!!!!
Hello World, I decided upgrade my old router, so i thought with the new Nighthawk XR1000. My old router is a Netgear Nighthawk X4S. Believe it or not, this new router is performing much slower th...
- Oct 19, 2022
Not at the moment. I use mostly default setting on my XR. Manual channel 1 and 40. This depends on any wifi neighbors you may have around you. 1,6, and 11 are primary channels to manually use on 2.4Ghz. 36 thru 48 and 149 to 161 on 5Ghz.
I have Smart Connect enabled. I believe MIMO is as well. Been running well since I put the XR online: 10/5
I also keep a laptop fan cooler under the router as well. Keeps it cool.
Oct 17, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How do you have the Wifi configured on the Basic Wireless and Advanced Wireless Settings?
What channels are you using?
How are you speed testing? Wired or wireless?
What devices are you using for speed testing? Wired is preferred for a 1Gb ISP service.
With wireless, depends on device design and support.
What I see with my Mac Book Pro 2018 and my XR1000 today:
Pretty good for 5Ghz AC which is top of the range for 5Ghz AC
bobbydigital00
Which settings should i be using? I'm tempted to just put the router in AP mode.
I purchased this router because the reviews all said this router could get the job done. I'm just guessing my configuration is somehow wrong.
I have a ATT Uverse routers. I'm using brand new CAT 6 cables.
I have not modified the advanced wireless settings as of yet.
- Netduma-LiamOct 18, 2022NetDuma Partner
You can find the clearest Wi-Fi channels in your area by simply downloading a Wi-Fi anaylser. There's a good one on the Microsoft store simply called 'Wi-Fi Analyser'.
You can try putting the XR into AP mode and re-test the speeds. Though doing this you will lose out on all the features of DumaOS, which isn't ideal.
Can you connect a device to the XR via ethernet and test the speeds there? Alternatively, can you run a Connection Benchmark by going to routerlogin.net in your browser, then to Connection Benchmark. What speeds do you see there?
- bobbydigital00Oct 18, 2022Apprentice
Hello,
I'm getting almost 950mb down and up when running the connection benchmark speedtest.
When I am hard wired to an Ethernet port on the router i'm only getting about 600mb up and 450 - 500 mb down.
- FURRYe38Oct 18, 2022Guru - Experienced User
What Firmware version is currently loaded? Mines on v.64
Mines on 1 and 40.
40Mhz only channel width on 2.4Ghz.
All additional Wifi features enabled under Advanced Tab/Wireless Settings.
Power 100%.
Slider bars at 99% for both as when I game, I'm generally the only one gaming thru the router at night.
GeoFilter is at default for my region:
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-modeTry #2 first.
I'm going to try your #2 solution and I will report back shortly.
Update,
I enabled Smart Connect and all the additional features under the wireless settings tab. I found an unused channel to use. This improved the wireless speed but I'm still not getting even close to the speed that is shown in the connection benchmark. In the connection benchmark it shows 905mb down and 937mb up. With my laptop sitting right next to the wireless router for testing purposes i'm only getting 380mb down and 400-460 up.
Hardwired to an ethernet port is improved speed but only by about 100mb at best and not consistent.
I took my old wireless router offline and powered it down for testing. So right now i'm only using the new router.
I'm going to test this in AP mode later this evening and I will report back.
I'm open to any and all suggestions to achieve better throughput.
Again, thanks for all responses.
- Netduma-FraserOct 18, 2022NetDuma PartnerI wouldn't necessarily recommend enabling all the additional features for wireless, that could hinder you. Smart Connect off would probably be best to connect to 5GHz manually for speeds.
You mentioned in your first post that you have a firewall controlling filtering and QoS:
1) Is this on the upstream modem/router and how have you configured this?
2) Do you still have devices connected to that modem/router?
3) What are you hoping to use the router for exactly if you're not using/interested in the main features? Depending on your answer AP mode might be right for you.
