bobbydigital00
Oct 17, 2022Apprentice
Nighthawk XR1000 SLOW....SLOW...SLOW...!!!!!!!
Hello World, I decided upgrade my old router, so i thought with the new Nighthawk XR1000. My old router is a Netgear Nighthawk X4S. Believe it or not, this new router is performing much slower th...
- Oct 19, 2022
Not at the moment. I use mostly default setting on my XR. Manual channel 1 and 40. This depends on any wifi neighbors you may have around you. 1,6, and 11 are primary channels to manually use on 2.4Ghz. 36 thru 48 and 149 to 161 on 5Ghz.
I have Smart Connect enabled. I believe MIMO is as well. Been running well since I put the XR online: 10/5
I also keep a laptop fan cooler under the router as well. Keeps it cool.
Oct 18, 2022Guru - Experienced User
What Firmware version is currently loaded? Mines on v.64
Mines on 1 and 40.
40Mhz only channel width on 2.4Ghz.
All additional Wifi features enabled under Advanced Tab/Wireless Settings.
Power 100%.
Slider bars at 99% for both as when I game, I'm generally the only one gaming thru the router at night.
GeoFilter is at default for my region:
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
Try #2 first.
bobbydigital00 wrote:
Which settings should i be using? I'm tempted to just put the router in AP mode.
I purchased this router because the reviews all said this router could get the job done. I'm just guessing my configuration is somehow wrong.
I have a ATT Uverse routers. I'm using brand new CAT 6 cables.
I have not modified the advanced wireless settings as of yet.
bobbydigital00
Oct 18, 2022Apprentice
I'm going to try your #2 solution and I will report back shortly.
