bobbydigital00
Oct 17, 2022Apprentice
Nighthawk XR1000 SLOW....SLOW...SLOW...!!!!!!!
Hello World, I decided upgrade my old router, so i thought with the new Nighthawk XR1000. My old router is a Netgear Nighthawk X4S. Believe it or not, this new router is performing much slower th...
- Oct 19, 2022
Not at the moment. I use mostly default setting on my XR. Manual channel 1 and 40. This depends on any wifi neighbors you may have around you. 1,6, and 11 are primary channels to manually use on 2.4Ghz. 36 thru 48 and 149 to 161 on 5Ghz.
I have Smart Connect enabled. I believe MIMO is as well. Been running well since I put the XR online: 10/5
I also keep a laptop fan cooler under the router as well. Keeps it cool.
bobbydigital00
Oct 19, 2022Apprentice
Thank you for your response. I am going to go with the EAX80. I believe you said this would be a good match for the router.
Also, are there any preferred settings I should be using between the router and the extender that you know of?
Oct 19, 2022Guru - Experienced User
- bobbydigital00Oct 19, 2022Apprentice
Got it. Thank you for your response. I will go with the EAX80 and see how this all works out.
Thanks again to everyone for your time and responses.
- FURRYe38Oct 19, 2022Guru - Experienced User
Enjoy. 📡
