aaravksr
Nov 17, 2022Aspirant
Nighthawk XR1000 Slow Speed
My connection Benchmark speed is 340 Mbps but when I check on speedtest.net and fast.com Then my speed is 100 Mbps. I facing this problem for three days but before three day ago speed was good everyt...
Nov 17, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
- aaravksrNov 18, 2022AspirantFirmware 1.0.0.64 Latest. Same cable which comes with router was working fine before with same cable.
- FURRYe38Nov 18, 2022Guru - Experienced User
Have you tired with disabling QoS, reboot the router then test with a wired PC and Ooklas installable speed test app?
Try speed testing with the wired PC connected to the ISP modem with out the router in the middle?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
- Netduma-FraserNov 18, 2022NetDuma PartnerHave you followed through the guide?
