aaravksr
Nov 17, 2022Aspirant
Nighthawk XR1000 Slow Speed
My connection Benchmark speed is 340 Mbps but when I check on speedtest.net and fast.com Then my speed is 100 Mbps. I facing this problem for three days but before three day ago speed was good everyt...
aaravksr
Nov 18, 2022Aspirant
Firmware 1.0.0.64 Latest. Same cable which comes with router was working fine before with same cable.
Nov 18, 2022Guru - Experienced User
Have you tired with disabling QoS, reboot the router then test with a wired PC and Ooklas installable speed test app?
Try speed testing with the wired PC connected to the ISP modem with out the router in the middle?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
