konradsroka
Dec 06, 2019Follower
Nighthawk XR300 2.4g and 5g merge
Is there any way to merge 2.4g and 5g on the Netgear Nighthawk XR300? I've seen someone be able to do this on a XR500 but i'm not sure if it's possible or not on this model. The firmware version is 1....
Netduma-Fraser
Dec 06, 2019NetDuma Partner
Smart Connect (the feature that allows this on the other XR routers) isn't available on the XR300 unfortunately.
