CharlotteX
Apr 21, 2020Tutor
Nighthawk XR300 and Huawei 612 Modem on Talktalk
Hi all, I've got a friend who is trying to set up her new XR300 with a Huawei 612 unlocked modem, and is having a lot of trouble. She is able to get th DSL light on the modem meaning that is receivi...
- Apr 23, 2020
Netduma-Fraser wrote:
The settings on that page indicate that a login isn't needed but VLAN needs to be set, was that done?Okay so managed to fix the issue, we had to go back in to the internet setup and manually set up the connection rather than using the connection wizard - this allowed us to set it up as not needing a username and password and to retrieve everything via DCHP -thanks for the help :)
Netduma-Fraser
Apr 22, 2020NetDuma Partner
Do you require PPPoE or VLAN for TalkTalk? The internet should get detected when going through the Setup Wizard, what did it say then?
CharlotteX
Apr 22, 2020Tutor
Talktalk uses automatic network auth for PPPoE which makes things awkward, the modem detects and accepts the internet but for some reason the router never. detects an internet connection
- Netduma-FraserApr 22, 2020NetDuma PartnerCould you follow this guide from TalkTalk and see if you can get it working please? https://community.talktalk.co.uk/t5/Articles/Set-up-a-non-TalkTalk-router/ta-p/2205383
- CharlotteXApr 22, 2020Tutor
Tried that unfortunately the netgear router doesn't let you not enter a username and password but Talktalk does not use them any more
Could you follow this guide from TalkTalk and see if you can get it working please? https://community.talktalk.co.uk/t5/Articles/Set-up-a-non-TalkTalk-router/ta-p/2205383- Netduma-FraserApr 22, 2020NetDuma PartnerI read from a different TalkTalk topic to just put in any username password so test & test for example, does it work after that? May need to reboot afterwards.
