CharlotteX
Apr 21, 2020Tutor
Nighthawk XR300 and Huawei 612 Modem on Talktalk
Hi all, I've got a friend who is trying to set up her new XR300 with a Huawei 612 unlocked modem, and is having a lot of trouble. She is able to get th DSL light on the modem meaning that is receivi...
- Apr 23, 2020
Netduma-Fraser wrote:
The settings on that page indicate that a login isn't needed but VLAN needs to be set, was that done?Okay so managed to fix the issue, we had to go back in to the internet setup and manually set up the connection rather than using the connection wizard - this allowed us to set it up as not needing a username and password and to retrieve everything via DCHP -thanks for the help :)
Netduma-Fraser
Apr 23, 2020NetDuma Partner
CharlotteX
Apr 23, 2020Tutor
- Netduma-FraserApr 23, 2020NetDuma PartnerThat's great to hear and thanks for posting the solution!
