DevilsBlubber
Dec 18, 2020Guide
NightHawk XR300 Pro Gaming router wifi networks offline while ethernet works just fine
Hello, I have had this router for a few months and had no issues with it. But when I came home today the two wifi networks (2.4 ghz and 5 ghz) no longer show up and are offline. I have rebooted the router multiple times from the software and also a hard reset from manually powering down yet they stay offline. I know its not a modem issue since the internet from ethernet cable connected from the modem into the router and then into my computer works just fine. So any suggestions would be great, thanks.
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
I will ask the Netgear moderator to move your message.
1 Reply
