DevilsBlubber
Dec 19, 2020Guide
NightHawk XR300 Pro Gaming router wifi networks offline while ethernet works just fine
Hello, I have had this router for a few months and had no issues with it. But when I came home today the two wifi networks (2.4 ghz and 5 ghz) no longer show up and are offline. I have rebooted the r...
- Dec 19, 2020In Settings > Advanced > Advanced Wireless settings disable both radios, apply, reboot, then enable, apply and reboot, then see if they work correctly please.
Netduma-Fraser
Dec 19, 2020NetDuma Partner
- DevilsBlubberDec 19, 2020Guide
Thank you
