Col52
Dec 10, 2020Follower
Nighthawk xr300 pro virgin media
Need to know if I can get this to work on virgin media . Thanks in advance
Netduma-Fraser
Dec 10, 2020NetDuma Partner
Yes absolutely, I have Virgin Media and it is very easy to do. You just connect the XR to the Virgin hub and enter the WAN IP of the XR into the DMZ function on the V hub interface.
