atomicdroid
Mar 18, 2023Follower
Nighthawk xr300 randomly reboots - revisited
Previously posted a message on this and then got busy and never came back to it. The wireless router is still randomly rebooting. I have: 1. Updated to the latest version of the Firmware 1.0.3.56...
Netduma-Fraser
Mar 19, 2023NetDuma Partner
What do you mean factory initializing it? It is a good update to do a factory reset after the upgrade in most cases. If you're connected using a power extender try direct to a wall outlet. If that doesn't stop it/it's already connected that way see if you have another power adapter with similar voltage that you can try.
