brodymc
Jan 25, 2020Tutor
Nighthawk XR300 Slow Speeds
Earlier this week I picked up the Nighthawk XR300 and I've been having a bit of issues with the speed. On my old ISP-supplied Huawei HG659b, I would get anywhere from 800-950mbps on my gigabit conne...
Netduma-Fraser
Jan 26, 2020NetDuma Partner
Okay for speeds double check everything here: http://support.netduma.com/en/support/solutions/articles/16000076586-dumaos-optimal-settings-guide-maxmimum-bandwidth-speeds
Regarding WiFi, go to Advanced WiFi settings, there are three options, Beamforming, MU-MIMO & HT160 - depending on your devices they may not work well with these. Experiment with them and see if you can get any higher at all.
brodymc
Jan 26, 2020Tutor
Okay, at work at the moment but I RDP'd home earlier and disabled beam forming & airtime fairness and I haven't had any complaints from the people at home yet... So I think that's the wifi problem solved.
I've already had a read over that guide before making this thread but I'll have another read once I've finished work and see if there's anything that I missed.
It seems the router is definitely capable of the speeds, but it has a mind of its own almost.
Thanks heaps for your help so far! I'll post back once I've gone over that guide.
