Noahbakke101's avatar
Noahbakke101
Nighthawk XR300 WiFi Dropping
All of my devices on my network keep losing connection, even hardwired ones. They are “connected” to the router still, but say “no internet.” This is a recurring issue the last couple weeks. Restarting the router by power cycling seems to temporarily fix the issue only for it to happen again a few hours later. Restarting the router via the nighthawk app doesn’t seem to solve anything. I only use the routers default settings. The only change I made was to turn off the guest network because I don’t need it. Maybe this is an ISP issue??
