kortex49
Aug 14, 2018Aspirant
Nighthawk XR500 - BT TV with Youview works for 4/5 and stops
Hi Netgear community,
I just purchased a Nighhawk Pro Gaming XR500 and althgouh the QoS, Devices and Network Management are working as designed, I am really struggling to get the BT TV working.
kortex49
Hi,
Thanks for taking the time to reply. Yes I registered the XR500 during its first installation. However, I can't find a way to get in touch to live or phone support via "MyNETGEAR".
I'm now considering returning this equipment, given it doesn't allow a basic functionality (watch BT TV) nor provide me, in an non-convolutive way, the possibility to contact the support of the manufacturer.
For reference, in attachement, the screenshot that shows that despite I've got complimentary paid tehcnical support until 08/09/18, I'm not allowed to contact them directly but only post on the community forum and search the knowledge base. Not the best experience :-)
Netduma-Fraser
Aug 14, 2018NetDuma Partner
Where did you purchase from? If you've only just bought it new then support shouldn't have expired. Did you get it second hand?
Can you help get kortex in touch with support?
DarrenM
Blanca_O
ChristineT
DarrenM
Blanca_O
ChristineT
- kortex49Aug 14, 2018Aspirant
Bought brand new from Amazon.co.uk last Wednesday.
Honestly, I had a look on many technical forums, it doesn't appear to have anybody with an XR500 who reported the fault that found a fix. In example, on this very much forum the gentleman decided to return his XR500 after having exhausted all technical possibilities.
Thanks,
Kortex
- Netduma-FraserAug 14, 2018NetDuma PartnerIt should be resolvable, hopefully one of the moderators will jump in soon to get you in contact with support.
- kortex49Aug 15, 2018Aspirant
Hi Fraser,
Again, thank for your constructive feedback.
For the reasons I mentioned earlier: router not able to support basic service in the UK (watch BT TV) and the fact I can't get support, even on a time limited basis, I've returned the XR500 back to Amazon.
Thanks,
Kortex
