ZONA69
Aug 06, 2020Tutor
Nighthawk XR500 - slowing my speeds down
So I have Cox Gigablast. Speedtest from modem directly to PC I was getting 750 download and 35 upload. When I connect through my XR500, the download speeds plumit down to 90 while the upload only sli...
ZONA69
Aug 06, 2020Tutor
I'm not sure what you want me to do. I don't see a speed showing for WAN/LAN. But I posted a screen shot of the table view in QOS. Link attached.
Netduma-Fraser
Aug 06, 2020NetDuma Partner
Thanks for the screenshot. The ethernet cable connecting your XR router to the modem is only capable of 100Mbits, you will need to use an ethernet cable that is at least Cat5e, you need another one for the ethernet cable in port 4 as well. Once you've done that you'll receive your full speeds.
- ZONA69Aug 08, 2020Tutor
Thank you so much. That definitely was the problem. Now my download speed is 760 and my upload is 35.
Netduma-Fraser wrote:
Thanks for the screenshot. The ethernet cable connecting your XR router to the modem is only capable of 100Mbits, you will need to use an ethernet cable that is at least Cat5e, you need another one for the ethernet cable in port 4 as well. Once you've done that you'll receive your full speeds.- Netduma-FraserAug 09, 2020NetDuma PartnerGreat to hear that, thanks for the update!
