ZONA69
Aug 06, 2020Tutor
Nighthawk XR500 - slowing my speeds down
So I have Cox Gigablast. Speedtest from modem directly to PC I was getting 750 download and 35 upload. When I connect through my XR500, the download speeds plumit down to 90 while the upload only sli...
Joeqmr2
Sep 28, 2020Aspirant
I have 500 upload speed coming out of my modem, but my out put is 123. I followed thred that suggested that I use at least a Cat5e model cable. That seem to fix the other persons problem, but not mine. I have Cat5e installed and still have slow output speed.
Help please
- Netduma-FraserSep 28, 2020NetDuma PartnerHave you input the speeds you expect into the Bandwidth settings? Are you using QoS?
- Joeqmr2Sep 28, 2020Aspirant
I'm not very techy, but it looks like my QoS is disabled. I don't know how to change expected bandwidth settings. Sorry
- Netduma-FraserSep 28, 2020NetDuma PartnerNot a problem, I would recommend you follow our optimal settings guides here which will also tell you how to get full speeds http://support.netduma.com/en/support/solutions/folders/16000090646
