ZONA69
Aug 06, 2020Tutor
Nighthawk XR500 - slowing my speeds down
So I have Cox Gigablast. Speedtest from modem directly to PC I was getting 750 download and 35 upload. When I connect through my XR500, the download speeds plumit down to 90 while the upload only sli...
Netduma-Fraser
Sep 28, 2020NetDuma Partner
Have you input the speeds you expect into the Bandwidth settings? Are you using QoS?
Joeqmr2
Sep 28, 2020Aspirant
I'm not very techy, but it looks like my QoS is disabled. I don't know how to change expected bandwidth settings. Sorry
- Netduma-FraserSep 28, 2020NetDuma PartnerNot a problem, I would recommend you follow our optimal settings guides here which will also tell you how to get full speeds http://support.netduma.com/en/support/solutions/folders/16000090646
