elCuculuz
Apr 29, 2020Apprentice
NightHawk XR500 and MullvadVPN
Hello! I got myself a new XR500 today and cant seem to figure out how to setup the VPN on it using MullvadVPN provider. I went on mullvad site and generated a config file but I dont have any idea...
- Apr 30, 2020Can you try this instead please:
client
dev tun
proto udp
remote-random
remote 31.170.22.2 1196
cipher AES-256-CBC
resolv-retry infinite
nobind
persist-key
persist-tun
verb 3
remote-cert-tls server
ping 10
ping-restart 60
sndbuf 524288
rcvbuf 524288
fast-io
auth-user-pass
reneg-sec 0
<ca>
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
</ca>
tls-cipher TLS-DHE-RSA-WITH-AES-256-GCM-SHA384:TLS-DHE-RSA-WITH-AES-256-CBC-SHA
Try m as the password if it doesn't work otherwise.
Netduma-Fraser
Apr 29, 2020NetDuma Partner
This guide should hopefully help you get setup but essentially you'll need to use the Advanced section of VPN Setup and paste that configuration file in and input your login details to connect. http://support.netduma.com/en/support/solutions/articles/16000087492--dumaos-optimal-settings-guide-hybrid-vpn
elCuculuz
there are 3 files in the downloaded zip I got from mullvad but they cant be opened to copy anything . sorry but it is a bit confusing .
- elCuculuzApr 29, 2020Apprentice
forgot to add also that mullvad uses a login token and has no password section I am a bit lost and confused after 6 hours of trying to configure it .
- Netduma-FraserApr 29, 2020NetDuma PartnerCould you attach the zips here so I could take a look please?
Could you attach the zips here so I could take a look please?I have uploaded the zip , hope this helps : https://filebin.net/cps99buo2nao98ca
And this is the mullvad site where I made the conf file https://mullvad.net/en/download/openvpn-config/#/
I have no idea what I am doing wrong that I cant connect to it .
