elCuculuz
Apr 29, 2020Apprentice
NightHawk XR500 and MullvadVPN
Hello! I got myself a new XR500 today and cant seem to figure out how to setup the VPN on it using MullvadVPN provider. I went on mullvad site and generated a config file but I dont have any idea...
- Apr 30, 2020Can you try this instead please:
client
dev tun
proto udp
remote-random
remote 31.170.22.2 1196
cipher AES-256-CBC
resolv-retry infinite
nobind
persist-key
persist-tun
verb 3
remote-cert-tls server
ping 10
ping-restart 60
sndbuf 524288
rcvbuf 524288
fast-io
auth-user-pass
reneg-sec 0
<ca>
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
</ca>
tls-cipher TLS-DHE-RSA-WITH-AES-256-GCM-SHA384:TLS-DHE-RSA-WITH-AES-256-CBC-SHA
Try m as the password if it doesn't work otherwise.
elCuculuz
Apr 30, 2020Apprentice
Netduma-Fraser wrote:
Could you provide the error log on the Hybrid VPN page from when it doesn't connect please, that might provide more of a clue as to why it isn't working.
I just had a look at the log section and it is empty not a single line of code
information page shows
This is when I enter to config file to advanced section.
Provider N/A Username 4653212572406 Country N/A City N/A Protocol N/A Status FAILED
And this is when I tried to use my firends HMA VPN , now it shows some logs but connection still fail.
Netduma-Fraser
Apr 30, 2020NetDuma Partner
client
dev tun
proto udp
remote-random
cipher AES-256-CBC
nobind
persist-key
persist-tun
verb 3
ping 10
ping-restart 60
sndbuf 524288
rcvbuf 524288
fast-io
auth-user-pass
reneg-sec 0
<ca>
</ca>
client
dev tun
proto udp
remote-random
cipher AES-256-CBC
nobind
persist-key
persist-tun
verb 3
ping 10
ping-restart 60
sndbuf 524288
rcvbuf 524288
fast-io
auth-user-pass
reneg-sec 0
<ca>
</ca>
- elCuculuzApr 30, 2020Apprentice
omg thank you so much !!This worked and now it is connected ! if I plan on changing a server what do I need to look out for to make it work again just copy the conf above the sert ?
- Netduma-FraserApr 30, 2020NetDuma PartnerGreat to hear that! If you want another server download the files as usual and then look for the remote line with the IP like this one remote 31.170.22.2 1196 and then just replace this line in this config with the line from the new config. Don't change anything else.
just one more question about the vpn and router .
I applied on the VPN traffic (Do not VPN these services ) but looking at my IP nothing has changed ?
how do I make sure or how to test that the vpn is tunneling my connection .
Disregard this question , it took a few minutes and is displayng now the spoofed ip.
Great to hear that! If you want another server download the files as usual and then look for the remote line with the IP like this one remote 31.170.22.2 1196 and then just replace this line in this config with the line from the new config. Don't change anything else. - elCuculuzMay 01, 2020ApprenticeCan you help me a bit regarding the IPs , I downloaded many config files to use diffrent servers with the router to see what has the best ping/connection/speed but I cant seem to find the IP to swap ``like this one 31.170.22.2 1196`` the config file does not have , it says only this in the downloaded file (remote-cert-tls server).
- Netduma-FraserMay 01, 2020NetDuma PartnerPost the contents of the file and I can have a look.
Thank you for helping me , here are the contents of them .
FINLAND
client
dev tun
nobind
persist-key
persist-tun
verb 3
ping 10
ping-restart 60
sndbuf 524288
rcvbuf 524288
cipher AES-256-CBC
proto udp
auth-user-pass mullvad_userpass.txt
ca mullvad_ca.crt
service mullvadopenvpn
block-outside-dns
remote-random
remote fi-hel-001.mullvad.net 1196
remote fi-hel-005.mullvad.net 1196
remote fi-hel-002.mullvad.net 1196
remote fi-hel-004.mullvad.net 1196
remote fi-hel-003.mullvad.net 1196
remote fi-hel-007.mullvad.net 1196
remote fi-hel-006.mullvad.net 1196FRANCE
client
dev tun
nobind
persist-key
persist-tun
verb 3
ping 10
ping-restart 60
sndbuf 524288
rcvbuf 524288
cipher AES-256-CBC
proto udp
ca mullvad_ca.crt
block-outside-dns
remote-random
remote de-fra-101.mullvad.net 1301
remote de-fra-103.mullvad.net 1301
remote de-fra-006.mullvad.net 1301
remote de-fra-007.mullvad.net 1301
remote de-fra-003.mullvad.net 1301
remote de-fra-008.mullvad.net 1301
remote de-fra-014.mullvad.net 1301
remote de-fra-009.mullvad.net 1301
remote de-fra-010.mullvad.net 1301
remote de-fra-005.mullvad.net 1301
remote de-fra-011.mullvad.net 1301
remote de-fra-004.mullvad.net 1301
remote de-fra-012.mullvad.net 1301
remote de-fra-102.mullvad.net 1301
remote de-fra-001.mullvad.net 1301
remote de-fra-013.mullvad.net 1301
remote de-fra-015.mullvad.net 1301
remote de-fra-002.mullvad.net 1301NORWAY
client
dev tun
nobind
persist-key
persist-tun
verb 3
ping 10
ping-restart 60
sndbuf 524288
rcvbuf 524288
cipher AES-256-CBC
proto udp
ca mullvad_ca.crt
block-outside-dns
remote-random
remote no-osl-007.mullvad.net 1301
remote no-osl-005.mullvad.net 1301
remote no-osl-001.mullvad.net 1301
remote no-osl-006.mullvad.net 1301
remote no-osl-003.mullvad.net 1301
remote no-osl-008.mullvad.net 1301
remote no-osl-004.mullvad.net 1301
remote no-osl-002.mullvad.net 1301London
client
dev tun
nobind
persist-key
persist-tun
verb 3
ping 10
ping-restart 60
sndbuf 524288
rcvbuf 524288
cipher AES-256-CBC
proto udp
ca mullvad_ca.crt
block-outside-dns
remote-random
remote gb-lon-014.mullvad.net 1196
remote gb-lon-013.mullvad.net 1196
remote gb-lon-009.mullvad.net 1196
remote gb-lon-008.mullvad.net 1196
remote gb-lon-002.mullvad.net 1196
remote gb-lon-202.mullvad.net 1196
remote gb-lon-010.mullvad.net 1196
remote gb-lon-012.mullvad.net 1196
remote gb-lon-007.mullvad.net 1196
remote gb-lon-003.mullvad.net 1196
remote gb-lon-004.mullvad.net 1196
remote gb-lon-006.mullvad.net 1196
remote gb-lon-201.mullvad.net 1196
remote gb-lon-011.mullvad.net 1196
remote gb-lon-001.mullvad.net 1196
remote gb-lon-005.mullvad.net 1196 - Netduma-FraserMay 01, 2020NetDuma PartnerYou can take the remote lines that have .mullvad.net etc and copy the entire line and replace the remote ip line in the config I gave you to change the server.
A huge thanks again ,it worked , something that simple and i missed it .....
I did some tests here and it seems that my DNS is leaking and my dns requests are exposed using a browser .
The IP is changed but I cant access geo blocked sites while using the routers hybridvpn, switching hybrid off and using the vpn app on windows it comes back safe .
is this reported and will this be fixed in the future .
- Netduma-FraserMay 02, 2020NetDuma PartnerYes it is something we're aware of, in Internet Setup use the DNS of the VPN and then it will work, not ideal but it works until we can do a fix.
