happiman
Nov 17, 2019Tutor
nighthawk xr500 ap mode mesh wifi
Hi there, I have a nighthawk xr500. It is currently running on AP mode, as my isp needs us to use their modem/router. I want to ask if it possible to use ex8000 on the xr500 to access mesh wifi?...
Netduma-Fraser
Nov 17, 2019NetDuma Partner
What do you mean your ISP needs you to use their modem/router? You've already connected the router to it so you can just put it in router mode and enable modem or bridge mode on the ISP router or put the XR500 in its' DMZ. I don't see why it wouldn't work, should be absolutely fine to do that if needed!
